[ID CC-CC2022] Изменить стиль линии в скрипте[js]
altertray
Помогите изменить стиль линии в скрипте, скрипт ставит вертикальную линию слева абзаца, нужно изменить тип линии с solid на thick-thick(двойная линия). Я в js вообще не шарю, пыалься что-то выловить что-то по смыслу в стиле, но ничего не нашел.
//DESCRIPTION: Add vertical paragraph rules to selected paragraphs
try {if (app.selection.length > 0)
    vertical_rules ()}
catch (e) {alert (e.message + "\r(line " + e.line + ")")};
function vertical_rules ()
    var vr, rule_length;
    var sel = app.selection[0];
    var p_first = sel.paragraphs[0];
    var p_last = sel.paragraphs[-1];
    var ascender = p_first.characters[0].ascent;
    var descender = p_first.characters[0].descent;
    var os = vrule_style ("vertical_rule___");
    // delete any vertical rules
    delete_rule (p_first, os);
    // add a rule at the first selected paragraph. We'll set its length later
    vr = p_first.insertionPoints[0].graphicLines.add ({appliedObjectStyle: os});
    // Two possibilities
    // 1. Everything on the same page: set the par. rule of just the first paragraph
    // from its first line to the last paragraph's last line
    if (p_first.lines[0].parentTextFrames[0] == p_last.lines[-1].parentTextFrames[0])
        rule_length = p_last.lines[-1].baseline - p_first.lines[0].baseline + descender + ascender;
        vr.geometricBounds = [0, 0, rule_length, 0];
    else
        // 2. The last paragraph ends on another page: insert a rule in the first line of last selected paragraph's frame
        // and extend it to the last line of the selected paragraph.
        // First set the rule at the first selected paragraph to extend to the bottom of its frame
        rule_length = p_first.parentTextFrames[0].lines[-1].baseline - p_first.lines[0].baseline + ascender + descender;
        // Then try to delete any v. rules in the first paragraph of the second frame
        var first_line = p_last.lines[-1].parentTextFrames[0].lines[0];
        delete_rule (first_line.paragraphs[0], os);
        // Now add a rule at the first line of the next frame and extend it to the last line of the last selected paragraph
        rule_length = p_last.lines[-1].baseline - first_line.baseline + ascender + descender;
        vr = first_line.words[4].insertionPoints[-1].graphicLines.add ();
        vr.appliedObjectStyle = os;
function vrule_style (s)
    if (app.documents[0].objectStyles.item (s) == null)
        var os = app.documents[0].objectStyles.add ({name: s});
        os.basedOn = app.documents[0].objectStyles[0];
        os.strokeWeight = "0.5 pt";
        os.enableAnchoredObjectOptions = true;
        with (os.anchoredObjectSettings)
            spineRelative = false;
            anchoredPosition = AnchorPosition.anchored;
            anchorPoint = AnchorPoint.topRightAnchor;
            horizontalReferencePoint = AnchoredRelativeTo.columnEdge;
            anchorXoffset = "6 pt";
            horizontalAlignment = HorizontalAlignment.leftAlign;
            verticalReferencePoint = VerticallyRelativeTo.lineAscent;
            pinPosition = false;
    return app.documents[0].objectStyles.item ("vertical_rule___")
function delete_rule (p, os)
    var g = p.graphicLines;
    for (var i = g.length-1; i > -1; i--)
        if (g[i].appliedObjectStyle == os)
            g[i].remove ();
function errorM (m)
    alert (m, "Error", true)
    exit ()
лень запускать скрипт, может хватит простого os.strokeType.name="Thick - Thick" ?
        os.strokeType = app.documents[0].strokeStyles.itemByName('Thick - Thick');
Или просто найдите в документе стиль объекта "vertical_rule___" и играйтесь с ним, как душе угодно.
Реакции: LeonidB и altertray
Спасибо, действительно легче стиль подправить. Хотя то что вы написали тоже работает
