Как расшифровать .xml file
NatalieRedFox_333
Здравствуйте господа !
Как расшифровать .xml file ?
собственно интересуют эти строки
        <operation>
            <search><![CDATA[if ((float)$product_info['special']) {]]></search>
            <add position="before"><![CDATA[
            $query = $this->db->query("SELECT d.filename, d.mask, d.download_id FROM " . DB_PREFIX . "download d LEFT JOIN " . DB_PREFIX . "product_to_download p2d ON (p2d.product_id = '" . $product_info['product_id'] . "') WHERE d.download_id = p2d.download_id");
            if ($product_info['price'] == 0 && !empty($query->row)) {
                $data['download'] = 1;
                $data['text_download'] = 'Download';
            } else {
                $data['download'] = 0;
            ]]></add>
        </operation>
весь код -
<?xml version="1.0" encoding="utf-8"?>
<modification>
    <name>Download Button</name>
    <version>3.0</version>
    <code>download_button</code>
    <author>xxvirusxx</author>
    <link>https://www.free-time-info.com/en/</link>
    <file path="catalog/controller/product/product.php">
        <operation>
            } else {
            ]]></add>
        </operation>
    </file>
    <file path="catalog/view/theme/default/template/product/product.twig">
        <operation>
            <search><![CDATA[<button type="button" id="button-cart" data-loading-text="{{ text_loading }}" class="btn btn-primary btn-lg btn-block">{{ button_cart }}</button>]]></search>
            <add position="replace"><![CDATA[
            {% if download == 1 %}
              <button type="button" id="download-button" data-loading-text="{{ text_loading }}" class="fa fa-cloud-download btn btn-primary btn-lg btn-block">{{ text_download }}</button>
            {% else %}
            {% endif %}
    ]]></add>
        </operation>
        <operation>
            <search><![CDATA[{{ footer }}]]></search>
<script type="text/javascript">
$('#download-button').on('click', function() {
  $url = 'index.php?route=product/download&product_id={{ product_id }}';
  $.ajax({
    url: $url,
    type: 'get',
    success: function(data) {
      if(data == true){
        alert('This file is not available for download.');
      }else{
        window.location =""+$url+"";
</script>
    ]]></add>
        </operation>
    </file>
</modification>
я понимаю так чтонадо найти строку
и добавить кусок
            } else {
            ]]></add>
только я не могу понять какую строку искать и куда вставить код....))) 'otbline'
а все...уже нашла что и куда вставлять....)))) :D
Реакции: _MBK_
кстати если кто хочет расширить свой кругозор -
