Kodak Magnus 400Q ошибка прожига
  • Автор темы Автор темы Kportnov
Kportnov
Добрый день. Есть проблема пока не знаю как решить. Может поможет коллективный разум. Прожиг проходит в штатном режиме. После прожига появлятся ошибка
Image data sent to the head was possibly corrupted. Check plate for artifacts
на пластине полосы.
\\\\\ниже кусок лог файла в момент появления ошибки
> S MPC: (ID:5) Plot: Imaging in progress
f 02Apr19 10:07:18.749: <MCE> S MPC: Elapsed time = 32.927 seconds
f 02Apr19 10:07:18.759: <MCE> E MIC: (Index=0) Updating image status to 0x0050 and GUI to 0x0130
f 02Apr19 10:07:18.769: <MCE> C GIM: Image ID5: Image status='IMAGING', GUI status='IMAGING'
f 02Apr19 10:07:21.333: <MCE> E MPC: Plot swath count = 11, 5% done
f 02Apr19 10:07:23.976: <MCE> E MPC: Plot swath count = 22, 10% done
f 02Apr19 10:07:26.620: <MCE> E MPC: Plot swath count = 33, 15% done
f 02Apr19 10:07:29.254: <MCE> E MPC: Plot swath count = 44, 20% done
f 02Apr19 10:07:31.898: <MCE> E MPC: Plot swath count = 55, 25% done
f 02Apr19 10:07:34.532: <MCE> E MPC: Plot swath count = 66, 30% done
f 02Apr19 10:07:37.165: <MCE> E MPC: Plot swath count = 77, 35% done
f 02Apr19 10:07:39.819: <MCE> E MPC: Plot swath count = 88, 40% done
f 02Apr19 10:07:42.453: <MCE> E MPC: Plot swath count = 99, 45% done
f 02Apr19 10:07:44.466: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:44.476: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
f 02Apr19 10:07:44.546: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:44.566: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
f 02Apr19 10:07:44.746: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:44.756: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
f 02Apr19 10:07:44.847: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:44.857: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
f 02Apr19 10:07:44.967: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:44.977: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
f 02Apr19 10:07:45.047: <MCE> *** Unsolicited Message 44301 Warning
f 02Apr19 10:07:45.057: <MCE> [CEH:Warning Fault [02517] Light Valve: A data overflow has been detected]
Господа, какие будут мнения?
Проверить для начала жёсткий диск и память на ошибки
Если не поможет -- рассказывайте подробнее конфигурацию аппарата и программного обеспечения.
(у нас что-то похожее стоит, пока такого не было)
HDD поменяли на SSD все тесты на ура. Аппарат Magnus 400 Quantium II выпуск 2007 год. Голова TH2 50Вт. Данные передает PC софт Kodak XPO. Подключение по SCSI 68 пин. SCSI контроллер Adaptec Fab 1817207-00 rev a APD-39160 mac 3892B365 контроллер в сборе 1817206-04. Кабель длинной 12 м. Внутри аппарата пата Turbo MCE сборка 10-4766D-E. Проблема проявлялась и ранее но эпизодически. Сейчас в 80% Ошибка возникает на середине прожига. Это видно из куска лога ниже. Пока никто не может сказать однозначно куда рыть. Даже сервисники, даже иностранцы. Предлагают все менять от скази до головы.
Either the exposure head has attempted to read data from the input buffer before the input buffer was ready, or the hotlink attempted to write data to the input buffer when the input buffer was full.
Я бы в первую очередь думал на SCSI адаптер. Если есть возможность - поищите аналогичный на замену. Стоит куда дешевле головы, найти только непросто.
Реакции: Kportnov
Спасибо. Вы имеете ввиду скази которая на внешнем компе стоит, данные в CTP передает? Завтра как раз приезжает новый SCSI попробую. Так же кабель новый заказал от компьютера до CTP. MCE перетряхнул, пыль убрал, все коннекторы почистил пересобрал. Память снял почистил поставил.
Да я в Томске. Я к ним обратился пару дней назад. Очень приветливые ребята. \подробности в личку напишу.
У нас несколько другая конфигурация. Кроме кабеля и адаптера -- посмотреть что там с терминатором.
Но (ИМХО), скорее всего, проблемы с кабелем.
Мы наблюдали подобное в двух случаях. Или умирает SCSI карта. Или проблема со шлейфами которые идут в жгуте к голове. Начните со SCSI карта. Это проще и дешевле.
