Ответ: Ошибка Экспорта в ПДФ - проблема с Джпегом
Индиз перелинкует автоматом все?
Да. Только надо указать ID путь через команду relink(или relink folder) в палитре link.
Relink to a different folder
When you use the Relink To Folder command, you can point to a folder that contains files with the same names as your out-of-date links. For example, if your current links point to low-resolution images, you can specify a different folder that contains high-resolution images. You can specify a different extension for the files, allowing you to change links from .jpg to .tiff, for example.
Select one or more links in the Links panel.
Choose Relink To Folder from the Links panel menu.
Specify the location of the new folder.
To use a different extension, select Match Same Filename But This Extension, and specify the new extension (such as AI, TIFF, or PSD).
Click Select (Windows) or Choose (Mac OS).
